Honda euX000i Fuel Extender
xzyHollyxyz
Does anyone have any experience with this generator run time fuel extender? Thoughts - good and bad?
Thanks.
2015 Fun Finder 189FDS
2013 Nissan Frontier Crew Cab SV 4x4
7 REPLIES 7
SCVJeff
Depends on how its milled. Just like any other screw or nut, one doesn't strip the other unless one is out of spec or has been mauled. Mine shows zero sign of gaulling.
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
mlts22
I know my inexperience is showing, but wouldn't a plastic cap be better, because a CNC milled cap does work and seal tightly, but might eventually strip the threads on the generator?
opnspaces
Navigator II
Navigator II
Yes on the surface it looks like a quality piece, but personally I would try to just buy the cap off ebay. The fitting that screws into the cap is available at Napa auto parts and the tank you can buy at Walmart.
SCVJeff
It wasn't cheap, but I bought a milled cap similar to this THIS
Jeff - WA6EQU
xaugievike
made my own and love it. nice to not worry about refueling ever few hours (esp if the AC running).
2015 Chevy Silverado 3500hd DRW.
Pulling Keystone Cougar 325SRX
A buddy and I started a blog - you can read it here:
http://twoguyscamping.blogspot.com
xzyHollyxyz
opnspaces wrote:
A lot of people seem to have and love their extra capacity generator fuel tanks. Most seem to be built using an outboard boat motor fuel tank. I would think the deciding factor on whether an extended run setup is worthwhile would revolve around the Honda fuel cap. If the cap leaks air, it won't be able to suck fuel from the tank.
Did you have a specific kit or tank you were considering? Could you link it so we could take a look?
Thanks
OP HERE - here's the link: Honda Generator Extended Fuel Kit
opnspaces
Navigator II
Navigator II
Thanks
