upstech76
Jan 18, 2014Explorer
Hot water heater problem
Helping a family member work on their TT. They have little to no water flow through the hot water tank. I've checked all the obvious and pretty sure a check valve is stuck but not sure where it is located. Here is what I know.
1. Water Input (bottom) valve is open.
2. Water Output valve (top) is open.
3. Bypass is closed (when I do open this water will bypass the heater and flows out the hot side of the kitchen/bath tap.
4. Hot water flows from the blow off valve when opened.
So the problem as to be between the tank and the T for the bypass right? Would the right angle piece coming from the tank contain a check valve? Would the output valve have a check valve in it?
![](http://i623.photobucket.com/albums/tt319/becca5880/IMG_0106.jpg)
Thanks in advance.
Michael
Thanks in advance.
Michael
