landyacht318
Feb 24, 2018Explorer
A 10 watt panel can indeed overvoltage fully charged batteries that have and have had no load on them.
https://www.youtube.com/watch?v=z5RtZe9AW2E&list=UUoPqTkOluQsuu3RpGnxVwFw&index=9
Do not assume anything with the intents of the people who made your RV, other than that they did every single thing possible to extract maximum profit at each and every stage of the design and build.
If you replace the 10 watt panel with a hundred watt panel, you will need to install a controller to prevent overvolting the batteries. Simple charge controllers capable of handling a 100 wat panel, are basically 4 wires to install, and can be had for as little as 16$ on Amazon, Perhaps less if one really is shopping for the cheapest of the cheap.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
