House/solar battery opinions
seraphim
My current battery space is 20"L x 14"w x 10"H
Going solar, and want to packs as much AH in there as I can (reasonably). Currently looking at 250 - 300. Price is not THE deciding factor, unless all else is equal.
I don't have experience with a lot of different companies, so I don't know who may a poor reputation. Some I am looking at:
http://www.apexbattery.com/group-8d-gel-solar-battery-solar-batteries.html $609 + $109 shipping)
http://www.atbatt.com/product/23216/sla/power-sonic/12v-150ah/battery#tabs ($774 for 300ah no nipping)
http://www.batterygiant.com/Product/8D%2DGEL (allegedly $577 (maybe $669) for 225AH can pick up locally)
http://www.mastervolt.com/marine/products/agm-slimline-12v/agm-sl-12-150/#specifications (can fit 2 185AH units in my space - haven't found an online price yet, which tells me something lol)
Any thoughts on these, or others you are aware of?
2012 GMC 3500HD Crew Cab LB 4x4 DRW with Duramax 6.6 diesel
2013 Palomino Maverick 2902.
179 REPLIES 179
mena661
smkettner wrote:
If it is just about saving money.... good luck. Better to just get the right equipment from the get go.
I have limited roof space. I want to be efficient in filling it, that's all. I would rather have one 300W panel and another 140-170W than three 140W panels or two 140's and one 170W. Both would take up the same amount of space (300W vs two 140W's) but the 300/140-170 combo puts out more watts overall. It would be a waste of money for me to buy a 30A Rogue for just the 300W for example because any subsequent panel couldn't be added to it unless the Vmp was really closely matched and most of the small panels are NOT 30+V. I might end up wasting watts potential because of controller expense. I thought I had a roof pic already but I'll take one tonight and post.
pianotuna
Nomad III
Nomad III
Isc = 6.29 amps @ short circuit
However they are $300 each.
full_mosey wrote:
PWM controllers use the Isc, not the Imp for charging current. Isc is 10-20% higher than Imp. Sometimes MPPT cannot even beat that!
What is the Isc of the 100W panels?
If we are going to eliminate PWM, let's do it right.
HTH;
John
Regards, Don
full_mosey
smkettner wrote:
Morningstar MPPT will choose PWM if output is higher. Nothing to lose.
Sweet!
HTH;
John
time2roll
full_mosey
HTH;
John
MrWizard
Moderator
Moderator
i think exspanion is dictated by sq ft of roof vs panels not number of watts
2*140 should take almost the same sq ft aka number of cells as one 300w
its easier to position multiple smaller panels that a few large panels
also from experince all this 'partial panel shading' comments don't mean much in real life use in the summer time
multiple 'parallel' panels suffer a small loss when one panel has a little shade from the A/C unit
no big deal.. its still more total power than you would get if that panel was not there.
NOTE I SAID PARALLEL
shading will mean more to snow birds in Az in the winter, but hey, thy can tilt them if they want
i would rather have a roof full of panels that ocassionasly get some reduced output than only a couple of perfectly mounted panels, my over all power gathered is greater
If i was designing a new system
it would be muliple 24v panels in parallel' with mppt contoller
and as many watts as i could get on the roof 'shading be danged'
mena661 wrote:
smkettner wrote:
Why would this be helpful? Not a best practice even if it works.
I was asking because I'm interested in that ETSolar 300W module which would be borderline with the 20A Eco-worthy MPPT controller. I figured maybe buying two of those and run them in parallel. It would be FAR cheaper than buying one 30A Rogue or the 45A Morningstar. I'd much rather have one 300W than two 140W units although the two 140's might be much cheaper. One 300W allows me to expand some in the future where two 140's might not allow that.
I can explain it to you.
1997 F53 Bounder 36s
pianotuna
Nomad III
Nomad III
Hi seraphim,
The numbers are not going to work as you hoped.
It is a bit more complicated. On an 18.5 volt panel MPPT is not going to give you nearly the gain you calculated.
You might well get more by going series/parallel on the panels so that input voltage to the mppt is 37 volts.
The PWM calculation is also too high.
seraphim wrote:
Let's do a comparison with the the Helios 300 watt 8.2 amps at 36.55 volts and the AM 100 watt 5.42 a,ps at 18.5 volts lets use 12v as the charging voltage for ease of calculations (there, PT, I said it lol).
Helios though an mppt 36.55/12*8.2 = 24.9758 amps
AM through mppt (18.5/12*5.42)*4 = 33.42 amps
AM through PMW 5.42*4= 21.68 amps
Ok. I'm man enough to admit I'm wrong. The AMs will put out more amps through the mppt. I didn't 'calculate' their higher voltage through an mppt - just the PMW.
Theoretically, with the 4 panels in a three hour period, I could generate enough amps to recharge a day's usage of 100 amps. It's going to cost me an additional $500, but...
I concede defeat
Regards, Don
seraphim
Thanks to everyone for putting up with me lol. I can be a PIA at times.
seraphim
SteveAE
Went out this morning and the numbers hadn't changer (apologies it was .1 amp). Changed P1 to 13.5, and the green light began flashing indicating a full charge, amps remained unchanged and battery showed 100%. Unplugged from 110, turned on a light, and amps changed to 2.7. Everything appears fine. Guess the battery was as fully charged as it was going to get, so it really wasn't drawing any amps.
Thanks for the suggestion.
Battery may have lost some capacity, but it should still tell me what I want to know.
seraphim
"If it is just about saving money.... good luck. Better to just get the right equipment from the get go."
Yes.
Also, just caught your answer to my earlier question - thanks.
time2roll
seraphim
Thanks for the explanation, Don
seraphim
I concede defeat
pianotuna
Nomad III
Nomad III
Hi seraphim,
It takes 60 watts per 100 amp-hours of panels to be able to equalize a battery using solar. In my opinion, that is the bare minimum number for wattage in a well designed system. So 480 amp-hours X .6 = 288 watts.
seraphim wrote:
I'm confused here. How'd you jump from amps (480) to watts? Is .06 a magic number of which I don't know the significance lol?
Regards, Don
mena661
