- ice2fireExplorer
mbopp wrote:
I have a SEA enclosure. One call & they shipped me 2 wiper seals. I just worked it into the groove with my fingers.
Are you sure the door isn't mis-aligned:
Shower Door Fix
Me too, although I had to look very hard for any identification of the shower. On the latch ! Thanks very much. The door is perfectly aligned. The seal has just melted away. I sent away for some new ones. It gets hot in AZ in the summer !! Enough to crack and crumble the plastic lid of the bathroom vent lid ! (Another maintenance job !) - Canadian_RainbiExplorer
Dave H M wrote:
my particular shower door has a lip on the bottom. When the wiper seal fell apart I trashed it and did not replace it. Never a drop of a leak at the bottom of the door.
X2 more or less. We were able to replace the first failure with a T shaped strip from the local hardware store. It fell apart last winter, couldn't find a replacement. The new "T" shaped strips were curved on the top and wouldn't fit. Finally gave up and left it as is.
Mid October we set of for warmer climes and are now in southern Mexico. No more drips on the floor than when we had the strip in place. Perhaps even less.
If you can't find one that fits, try it without. - Dave_H_MExplorer IImy particular shower door has a lip on the bottom. When the wiper seal fell apart I trashed it and did not replace it. Never a drop of a leak at the bottom of the door.
- MerkelGExplorerI went to ace hardware . They have stick on seals that you can trim to fit.
- mboppExplorerI have a SEA enclosure. One call & they shipped me 2 wiper seals. I just worked it into the groove with my fingers.
Shower Door Fix
