pianotuna
Nov 09, 2023Nomad III
His charging is all solar for that battery--so he is not charging below the temperature at which lifepo4 can be safely charged. iirc he also says it is low rate--but doesn't specify a number. Too little data.
I also said that charging at -34 F doesn't work well for this chemistry.
Again LI are the cats meow except for truly cold weather.
