How can I check to see if voltage to pump is enough m..slide is very slow..mcant find a bind, has fluid, can't find any leaks 1997 Winnebago vectra , Chevy workhorse Thanks in advance
Well I replaced the solenoid and slide would move but motor just wont seem to stay running. I could get it to budge out a tad then stop. Tried the jacks. One rear jack came down, touch the ground and then go back up. After that tried the retract and very very slowly it moved enouf for me to get it back in the full retract position. baffled i am..
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
