- thewilsonsExplorer
rockhillmanor wrote:
Nice DIY repair!
I used JB Water Weld.
Incredible stuff. You can actually use it for under water repairs! I keep it on board for god forbid I get a leak in one of my holding tanks etc. No need to drop tanks just slap this water weld on it.
I cracked my shower around the drain. Fine line cracks and didn't know either until the carpet started getting wet.
FYI. I started using the shower to store some of my stuff while on the road instead of putting it in the bays between destinations.
The weight of these items bouncing up and down is what cracked the pan around the drain. duh.
JB's New Water Weld product
thank you , the stuff I used cracked I tried the stuff you recommended "water Weld" and it's holding up great. - BarneySExplorer IIIMoved to Tech Issues forum from DIY.
- rockhillmanorExplorer IINice DIY repair!
JB's New Water Weld product - mikebreezeExplorerNice video. I'll try some of that JB Plastic Weld as I have a crack between the floor and wall seems in my shower.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
