NetComrade
Jul 21, 2013Explorer
How much capacity does the TV plug have?
This is my only 12v outlet, and I plugged a 4 way splitter into it.
The outlet does say "tv only".
I can easily run my
router (direct DC plug) ,
plus fan 1.3A amp 12V,
but anything else after that I can only have one off
12v->20V laptop (says 10A max, not sure what it draws constantly)
185W 12v-110v that i need for my VOIP phone (required 24V, less than an amp, says 400mA on the power supply)
inverter is: Duracell DRINVP175 175-Watt Pocket Inverter with 2.1-Amp USB Port, I bought it because the fan is least loud.
Verizon Samsung network extender (direct 12V 1.5A)
so I end up juggling between my laptop and my phone. I keep the extender offline, as it doesn't work anyway, but I would like to be able to have all of them on.
Is there an easy (cheap) way to monitor amp drawage on the cigarrette plug?
Could my 185w inverter be drawing more than it needs (the phone requires very little power, i don't know why it's NOT 12v)
The verizon extender appears to be very sensitive to voltage drops. I can certainly judge by the fan speed whenever it it drops.
Fusebox says 15A for TV radio.. maybe the wire is too thin for the load? I certainly have enough power overall.
I can easily run my
