time2roll
Oct 31, 2023Nomad
Generally LFP will rest fully charged at 13.4 volts. Need a bit more to actually charge so 13.6 is fine but will take an extended period. 14.2 to 14.4 is certainly faster.
The good thing is charging to 90%-95% will not cause a loss of capacity like lead-acid over time. And the LFP will definitely charge faster than lead-acid at similar voltage.
Solar panel may eventually cause LFP to go to over volt protection if used during storage.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
