vermilye
Nov 02, 2023Explorer II
Boomerweps wrote:
Your existing converter will take care of most of the charging but take a longer time. Your solar should take care of reaching the higher voltages needed to reach 100% and equalizing the cells. That’s what I’m currently doing. I do have a lithium capable stand-alone charger that I used before permanently mounting solar panels.
I do much the same. I did switch to a PD4635LIV converter, but almost always leave it in the lead acid mode because I don't like the 14.6V float the lithium mode provides. I have 320 watts of solar on the roof & a Victron solar controller that keeps the lithium batteries topped off. A bunch of days in the shade but plugged in shows around 95% charge on the Victron 712.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
