MEXICOWANDERER
Jul 12, 2018Explorer
I've seen too many micro Onans to believe in the tooth fairy. If the slight surge does not worsen and electrical output values do not escape the acceptable window I wouldn't worry about it. Woodward electronic governors are extremely expensive and the only small Onan I have seen run flawlessly was a 22 horsepower 4 cyl powering a 12,000 watt generator and it was on LPG. It had it's own problems with engine overheating > 9,500 watts. The old saturated field 6.5 NH was notoriously fickle but it was near bulletproof.
Trying a brand new carburetor is going to be pricey. I hope it works for you.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
