joebedford's avatar
joebedford
Nomad III
Nov 20, 2024
How to get rid of a few roaches while we live in the RV
The latest problem that we have is some roaches. While it's fun watching the cats go after them (just like a laser pointer) I'd like to get rid of them. Our rig was stored for a few months backed into a slightly jungley area in FL. We must have picked up some passengers there. What do you use to get rid of roaches while we're in the RV? We've been wintering in our RV for over 20 years and have never had this problem before. I don't think there are a lot of bugs, but there's definitely more than one.
  • If you can go north in the winter and then let the rig freeze for a couple days, that will get them. We had a minor issue on our boat after transiting S. Carolina and couldn't fully eliminate them. Wound up storing her in Michigan for the winter and never saw another one.
  • Never had roaches in an RV before, but living in the south and our property bordering on wetlands we get the occasional "palmetto" bug. Advion gel works better than anything I have ever tried. You can buy it on amazon. It's not a spray or kill on contact. It's a food that they ingest, and it will eventually kill all of them. Works in about 24-48 hours. Safe for pets (only affects things with an exoskeleton).
    • joebedford's avatar
      joebedford
      Nomad III
      I'll try that.
      Does it do any good to fill the holes in the floor where the plumbing and wiring comes in from the basement? There are holes in the toilet area, galley, powder room and washing machine area. Plus others I've never seem?
      • naturist's avatar
        naturist
        Nomad II
        Those holes are open invitations to mice, roaches, ants, etc. I would suggest loosely stuffing a little steel wool in the hole, then giving each a shot of spray foam to seal. Easily enough gouged out if you ever need to reopen to make repairs, but not possible for the varmints to chew through.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
