TurnThePage's avatar
TurnThePage
How to ground FM antenna?
I'm adding a "real" antenna to my travel trailer. I'm mounting it in the center of the roof, which is rubber on plywood. It has a ground strap which ideally should be grounded to the frame. That would take a fair amount of work. What are the drawbacks from using the 12v ground connection for the stereo?
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
