- bigorangeExplorerPretty sure I have the same outlet on my trailer...I found this plug that fits it. You might be able to use this with whatever panel you decide to use.
Amazon link - Z-PellerExplorer
I am buying a portable solar panel. Do I just plug it in or is there more to it?
Look at buying a solar charging kit or suitcase solar charging kit. It will come with a controller already attached and 10 feet or so of wire. You may have to adapt the solar wire connector to be compatible with plugging in to your trailer solar receptacle..... - BFL13Explorer IIA portable solar kit will have wires from it with battery clamps, so ignore the OEM connection point and just clamp on to your house batteries--assumed to be accessible from outside the RV.
If you make your own portable set, same thing. A trailer can use an adapter to the 7-pin to reach the batteries too, but a Class C doesn't have that of course. - ppineExplorer IIIBuilt in controllers are usually for crummy little solar systems. Figure out your system, cables, controller and fuses before you plug anything in.
- red31Explorer
LarryDel wrote:
Solar Ready outlet. I am buying a portable solar panel. Do I just plug it in or is there more to it?
if the brand of plug is different from the panel kit it would be best to determine the polarity of the kit and plug to determine they are the same. Zamp solar ready likely be backward from others! rewire it or get the adapter but check the polarity - LwiddisExplorer IISet up in the morning, move it with the sun, watch for theft, take it in to go to town, return, set up again, move with sun, watch for theft and take down. Repeat next day.
Put the panels on the roof! - Boon_DockerExplorer IIIWith portable you should be able to just plug it in.
Portable solar usually has a controller built in. - 2oldmanExplorer IIThere's more to it. I would surmise that's nothing more than a connection for wires that run to where your batteries are. You'll need a controller.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 21, 2025
