MEXICOWANDERER
Nov 24, 2018Explorer
HP Fuel Injector Line Modifications?
I want to put a RAcor fuel water separator on a toad. It has fuel injection the pump is in the gas tank. I believe the pump pressure is around 45 lbs.
The factory fuel filter is located near the r/r fenderwell. It has two slightly different diameter steel tubing projecting from the filter. The stubs use some sort of locking clip rather than a clamp. There is a ring around each of the filter's tubing stubs.
Does this sound like standard fuel line parts? Or factory special custom fit? High pressure gasoline is nothing to fool around with.
So educated advice is much sought after.
Thank you.
PS RAcor approved a few models OK for this application.
Thank you.
