dougrainer
Apr 09, 2018Nomad
kmb1966 wrote:dougrainer wrote:
I did not state 10 amps per coil.
I stated that each coil is PROTECTED by a 10 amp fuse. Doug
I tried putting my multimeter on amps and see what it is pulling but I could not get an accurate reading. I pushed 'store' and then took the reading, it only read 0.01 so I'm thinking I took the reading incorrectly, or it is only pulling amps at the moment that the 'store' button is pushed. But since it does not blow a 40 amp fuse, but it will blow a 15 amp fuse, I think I can assume it is pulling more than 15 amps, but less than 40. I might put a 30 in there and see if it blows the 30. New fuse holder gets delivered in a few days.
In STORE, all 4 solenoids are powered, not just one. Doug
