3Lakes_Steve's avatar
3Lakes_Steve
Hydroflame Furnace
I have a hydroflame 8900 II furnace in my RV, which will not ignite. Does anyone know a way to verify the gas valve is opening? The led on the circuit board indicates power to the valve, which I verified with a meter, and the coils on the valve tested OK as well.
I can hear the igniter clicking, but don't hear anything from the valve itself. Propane tank is about 1/3 full, and the heater worked fine before. If the valve is opening, but failing to ignite, I think you would get some faint smell of propane from the exhaust port?
I pulled the burner assembly, the electrodes look good, and have about the 1/8" gap recommended.
Looking for ideas before I buy a new valve
Thanks
Steve
