maillemaker
Apr 22, 2018Explorer
Well. Today was a good day, all things considered, I think.
We had nice weather, so I went and fetched the RV out of storage and parked in my driveway and got the genset side of the generator jacked up and on jack stands and dropped the generator on its hinges.
Pulled the two bolts holding the ignition control module in place, and....it would not come out. I tried rotating the engine by the 3/8" hex in the nose of the genset, but no matter how I tried, I could not find the right angle to pull the module out! More on this later.
Meanwhile, while I could not pull it out, it sure as hell goes in, because I let go of the bracket and POOF it fell down into the genset housing. While I still had ahold of it from its cable, I could not get it out of the genset no matter how I tried.
So, I pulled the entire genset out of the RV. Turns out this was actually pretty easy. I went and bought a 1000-pound rated $10 4-wheeled moving dolly from Harbor Freight, and positioned it under the genset and blocked up 4x4s until I was nearly under the genset floopan. Then I jacked it down onto the blocks. Then I went under the RV with the jack and removed the hinge keeper plates, jacked the inside of the genset to lift it off the hinges, and then slowly let it down onto the blocks. Then I was able to wheel the set out of the RV compartment.
All of the major connections (battery, fuel) were easy to get to and disconnect, and the main AC output terminated in the roof of the compartment in a junction box that was accessible from under the kitchen table bench seat, so it was easy to disconnect that trunk and then wheel the entire genset to my garage. I got the neighbor to help me lift it up onto my workbench:
On the workbench:
Gee, it's much easier to work on a generator when it's on a workbench!
So I made myself a little fishhook out of a length of wire and was able to grab one of the mounting bolt holes on the ignition module bracket and finally was able to get the bracket back out of the housing. But I still could not get it out, no matter how I tried to work it between two fan blades!
It won't come out:
So I slowly turned the engine with a wrench, and then I noticed that one, and only one of the fan blades is slightly shorter than the all the others. With this fan blade in front of the module, the module comes out easily!
The short fan blade:
So, now I have the module out of the genset.
Module out of genset:
And with the module out of the way, I was able to turn the motor completely and lo and behold, my ignition rotor is there and completely intact!
One end of the rotor:
So, is this module wired up properly?
So, it appears that my rotor is intact. So that is not the problem. The next step will be to figure out how to test the ignition module itself.
This replacement part:
http://www.partsfortechs.com/asapcar...nan-p-350.html
Does not have 3 leads coming out of it like mine does. Why?
So, the good news is my rotor is intact so I don't have to separate the generator from the engine. The bad news is I still don't know why I'm not getting any spark.
Also, I do not know how to make sense of this:
Make certain of coil polarity: the negative (-) terminal connects to the ignition module (black lead), and the positive (+) terminal connects to the ignition module (black lead), and the positive (+) terminal connects to a battery positive source within the control, to the ignition module (red lead), and to filter capacitor C4.
This passage seems contradictory - it says that the black lead of the ignition module connects to both the positive and the negative terminal?
I think it is probably a typo and it should probably read like this:
On further investigation, my ignition control module is strange.
The module itself has a red and black lead, but the red lead appears to be spliced somehow. I noticed it when I pulled back the white thermal insulation.
One of the splices is labeled "T1 +", and the other labeled "GND", which is where they both appear to be hooked up.
My module does not seem to jive with the Service Manual description.
What is the black thing with 4 terminals on it that attaches to the genset housing above the starter? (already found out, it is the battery charge resistor)
Steve
On the workbench:
It won't come out:
Steve
Jamiegoroski
Apr 27, 2024Explorer
Did you ever find out the problem? Where it says what's this do you know what it is? Thanks!
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
