john_bet
Jan 11, 2014Explorer II
Dusty R wrote:The same way the utility does for your house out on the pole except on a much smaller scale. The neutral and equipment ground are separate. In the case of this item the equipment ground(ground) from both cords are is bolted to the side of the case with a lug.
But how can you put one 120v leg in and get 2- 120v legs out ?
Or have they seperated the ground and neutral ?
Dusty
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 26, 2025
