MrWizard's avatar
MrWizard
Moderator
May 27, 2023
I know it's Spring , But this is interesting
This might prove useful to some of you, a fan that will attach to the top of your Buddy Heater to better circulate warm air, no Batteries needed, it works by using heat to create the power needed, it has a "Thermal Electric Generation" device in its base, its the reverse of the solid state DC cooling devices Used in 12v fridges and coolers,
That's what thermal couples do, use heat to create power to open a gas valve,
This makes enough electrical power to drive 2 fans.
Fan for Heater or Fireplace
I was researching Stirling Engine Devices when i came across this
  • I have a similar fan, same principle. It works well with the Buddy Heater. The base of the fan is flat to sit on a wood stove or similar. I haven't done it yet, but I've already figured out how to modify to sit securely on the Buddy.
Having RV issues? Connect with others who have been in your shoes.24,245 PostsLatest Activity: May 11, 2025
