time2roll
Mar 14, 2020Nomad
If it was your main charging I might be a bit more concerned but you mention solar should do most of the heavy lifting. If plugged in you have tons of time so no worries there either. OK on Generator you might lose 10 amps the first hour so you might have to extend the run time 15 minutes. Would seem to be OK to me for infrequent use.
