MEXICOWANDERER
Mar 16, 2020Explorer
Alternator only in danger if it has a voltage regulator with remote sensing. All of my systems have intergral sensing.
Load-dump causes rectifiers to fail not running with correct voltage reference. Running with batteries cut out from voltage regulator sense broken or switched off can cause deadly AC voltage. Hundreds of volts and several dozens of potential amperage within the cut output wiring. Yes I mean deadly.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
