Chris_Bryant
Sep 17, 2015Explorer II
If you have 12 volts (nominal, of course) at RH, then W should have 12 volts when calling for heat. Make sure W is connected to the "cold" thermostat lead from the furnace. Try setting heat to electric, rather than gas. (or vice versa).
