d3500ram
Sep 22, 2015Explorer III
Installing roof snow/ de-icing heat cables on roof...?
I am going to install roof snow/ de-icing heat cables on a portion of roof that is prone to ice damming. The repeating WWWWW pattern at the eave overhang makes sense, but what about the valley?
I have a 4/12 pitch, 6'-0 on one side and 20'-0" on the other with the valley rising about 23'-0" to the ridge.
I want to run the heat trace up the valley- should I do a criss-cross pattern similar to the WWWWW but running it up the valley or can I do 4 straight runs parallel to the valley (2 on each side.)
I am leaning towards the straight run pattern because it will be an easier install. I cannot have the cables overlap; if I do a criss-cross I would have to do the pattern up one side of the valley and the same on the other side to bring the cables down... lot of clips and spacers needed for that.
Thoughts?
Thoughts?
