ndrorder
Oct 01, 2018Explorer
Amps flow from higher voltage to the lower voltage. If the alternator is producing more voltage at the trailer battery than the solar controller, the controller should turn itself off and all of the alternator amps would go to the trailer battery. If the solar controller is producing more voltage at the trailer battery than the alternator, then there will be no amperage transferred from the alternator to the trailer battery.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
