RoyB
May 07, 2015Explorer II
I like that as well. Will still need some good self-tap bolts going into the frame with star washers to make sure the assy is at good ground.
I stock on these frame ground kits from PEPBOYS when I got a battery project going that comes with drill and tap. They use self-tap large screw heads that have the built-in star washers under the heads after you drill the hole in the frame. Like they use on automotive grounds...
Those last a long time for me after I install just one 2AWG or 4AWG ring terminal cable end.
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,216 PostsLatest Activity: Mar 15, 2025
