lawrosa
May 10, 2017Explorer
Inverter for RV hookup. Manufacturers reply.
Hi all. So I read contless online info about the whole bonding issue with Rv,s.
I understand the RV is basically a sub panel. The bond is made when you hook up to the pedestal. OK.
with a generator I guess who you talk to you can run both ways. Bonded gen or no bonded gen.. I have a kohler 2800 bonded gen with GFI.
OK now to my inverter that I will hook up in the camper. I will be plugging the RV umbilical cord into the inverter. ( I will turn off charging circuit at converter)
The inverter will be a krieger 1100 model. I already bought it as it has a 3 yr warranty. Upon a test of the invertor with my test plug inverter show open neutral/ground. ( Meaning its not bonded)
I did a test and got continuity from the ground plug to the grounding terminal on the case of inverter.
So I was not sure to make a plug or not to bond the G/N at the inverter. Or leave it as a floating neutral for when I plug in.
Here is my question and response from krieger.
Do you guys know what this means?
Does it mean I should disconnect the ground wire in the dog bone connector I make and just use the hot/neutral wires when connecting to the inverter?
If so can any electricians out there tell me why to do this?
I dont think customer support guy understood what I was doing and he may be wrong...
Question and reply to krieger..
HI,
Possibly you can help me with a technical question.
I have a Krieger 1100 watt inverter. I will be installing this in my rv travel trailer.
The travel trailer is basically a sub panel. So when I plug into the camp grounds pedestal I get the bond at the service entrance.
This would also stand true I assume for my 2800 watt gas generator. When I plug the RV to that I get the bond from the generator. This generator is bonded neutral/ground.
I notice your invertor has an open neutral from my test light. I will
be running a ground wire from the back of the unit to the trailers frame.
What I am going to do is essentially plug the RV into this invertor to power it. This will power all my outlets in the trailer. I will be turning off the charging circuit so there is no endless loop going on.
I am not sure if I should bond the N/G in the krieger invertor. I would plug a n/g plug into the extra outlet to accomplish this.
1. Should I leave this as an open neutral unit or make N/G plug to
bond the neutral and ground? ( Attached is an image of said plug) 2.
What gauge wire should run from grounding terminal in back of unit to
frame of trailer? ( I was going to use 6 gauge)
I hope you understand this and can help me.
Thanks
Mike NJ
HI Mike,
Thank you for the provided information about your application. We recommend using only the hot and neutral on the plug only and do not use the AC ground when connecting the inverter to a breaker panel box. You should use #10 gauge cable when connecting the ground chassis located on the back of the inverter to the frame of the trailer.
Customer Support
Krieger Manufacturing
2933 W. Cypress Creek Road, STE 202
Fort Lauderdale, FL 33309
Tel: 1.954.603.4950
Ok just to be clear in laymans terms,
So you recommend just plugging the RV into the krieger inverters outlet, with no modification to the neutral/ground, even though it will show as open?
Yes I will use 10 gauge or better for the chassis ground.
Also would you be able to supply a schematic for this 1100 watt inverter?
Thank you for your time. Its much appreciated......
Regards
Mike NJ
The modified wave inverter shows an open or floating ground compared to power received from your AC wall outlets. This results in a incompatibility when connecting to a breaker panel box. The best way is to just use the hot and neutral legs on the inverter's AC outlet and do not use the ground connection when connecting to a breaker panel. We still recommend grounding the inverter by connecting the 10 AWG cable to the ground chassis terminal located on the back of the inverter. You can consult with a qualified electrician for proper installation if needed. We do not provide diagrams, schematics, or a parts list to any of our products due to proprietary reasons.
Customer Support
Tel: 1.954.603.4950
