eaglet's avatar
eaglet
inverter not working
Solar system installed not quite three months ago. Worked great! Got home and a week later the inverter quit working. Called the manufacturer who says to return it. Sounds like a short circuit.
Called the installing company several states away for info on removing the inverter safely and was told to just take it out and he'd never heard of one going bad. (??!!!)
The first one they installed didn't work so we paid for a lot of extra labor getting a new one in.
Question: what do we do to protect the solar system/batteries until the new inverter comes. Also, anyone else have problems with inverter ???
  • eaglet wrote:
    Wondering if we should leave a light on or something to draw some power from the batteries while the rig is in storage. -
    Verify the the actual battery voltage if you need assurance.
    Otherwise the leave the light on will just appease Tom Bodett ;)
  • No....need to leave a light on
    The solar "Controller" will keep the batteries at the correct charge
  • eaglet wrote:
    There is a controller that we are hoping/assuming is still at work protecting the batteries from being overcharged. The panel shows the batteries are fully charged and in float. Nothing is on now to draw power. The 12 volt system still works. Its not on shore power.
    Why?
    Most of us try to stop current draw from the battery.
  • The inverter is a Cobra CPI 2575. We did ship it off. There is a controller that we are hoping/assuming is still at work protecting the batteries from being overcharged. The panel shows the batteries are fully charged and in float. Nothing is on now to draw power. The 12 volt system still works. Its not on shore power.
  • Its not clear to me whether you really mean inverter or converter. If you are worried about the battery being discharged you can just disconnect the negative connection to the battery. Should be good for several months if fully charged now.
  • 2oldman wrote:
    Protect from what?
    My thoughts also. Removing an inverter shouldn't have any effect on the solar system or batteries.
  • It's this an inverter only
    Or is it, a combo unit inverter and converter/charger
    If you are really worried, in this order
    Disconnect shore power
    Disconnect solar from controller, don't short out the wires
    Disconnect batteries from system
    Now disconnect and remove inverter
    To install repeat in REVERSE order
    I suggest you get somebody, who knows, to help you
    Protect from what?
  • Often there is lots of easy help available on this forum.
    Your inverter converts 12 volts back into usable 120 volts for regular household circuit small appliances.
    Your converter coverts 120 volts into 12 volts and charges your batteries.
    Your charge controller monitors the output of solar panels and protects your batteries from overcharging.
    So please, tell us what particular device and model you are having problems with, and what is happening with some real numbers.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
