westend
Sep 04, 2015Explorer
I would replace the bad one with a 500W PSW inverter for just the refer... a 2000W is four times what it needs. This would let you turn off the MS2000 when out of the rig saving some power.
500W will probably not overcome the LRA of the reefer. A user would have to check the idle draw of the inverters to be used. Some of the newer, larger inverters have a very low idle draw or an auto-shut off feature to save some AH's.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
