campigloo
Apr 11, 2021Explorer
Is my inverter fried?
Hi y’all.
I have a 2kw Renogy inverter/charger/auto transfer switch connected to 4 Lifeline 6v agm batteries, wired series/parallel. Just for fun and to see what affect it would have on the batteries I plugged a 5k btu air conditioner in. It has a 4.6 amp draw and the batteries were at 13.1v. It ran fine for about 5 minutes and I turned it off to see how the batteries responded. They went to 12.9. I plugged the ac back in turned to fan only and nothing! Turned the inverter off and a couple of minutes later the lights flashed and less than a second later, nothing. Plugged into shore power, nothing. Is this just typical Chinese quality? It’s been mounted in the camper since Dec 2019 with moderate to light use and has worked fine up until now.
TIA for any thoughts!
