is one 12 volt grp 31 battery enough for me
dave17352
Well here is the deal. I at this time unfortunately only have the chance to go out a few times a year. Previously we were able to go on much longer more frequent trips. I have a 2000 watt inverter in my 5th wheel. It was put there to run my cheap Hair 10 cubic foot fridge while on the road and overnight. I have a generator so it can be charged up at anytime. I want to buy just one good 12 volt battery to run that fridge if possible. Like I say being used just a few times a year. I also want to switch it back and forth to my TC. So what do you guys think would just one 12 volt do the trick. This battery is wired right next to the inverter with the proper gigantor gauge wire. As you can see I am not a electricity guro but I know at the time I set it up with the proper gauge wire, thanks to this forum.
thanks
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
25 REPLIES 25
MEXICOWANDERER
The Lifeline 31XT is only 105 amp hours. A bonus with the HT is its ability to run a 900 watt microwave at Full Tilt Boogie using a sufficient pure sine wave inverter.
Jesรบs, just told me he fried the board on my 1600 watt LG commercial microwave while running it on my TRACE 4024 pseudo sine wave inverter.
Lessee, that makes the 3rd time the board has fried on inverter power in the last ten years. Yet the microwave clocks what, <1% of it's run time on modified sine wave? This was a thousand dollar stainless steel commercial microwave. He was operating it on "4" which time pulses the energy to heat up three cups of coffee.
LG is not junk. Their commercial model even less so. The refrigerator and the freezers all have electronic controls, and they haven't failed. But the three other microwaves including inverter models all failed while on inverter power. Two blew their magnetron. I am willing to forgive two blowouts while on inverter but not not three times.
Lithium Ion. this setup needs superb management both for charging and discharging. Not: "here-today-gone-tomorrow" reliability. Overcharge once, it's a goner, overdischarge once, pounds a stake in it's heart. So it's not merely the battery that has to lower in price - but a management electronics and monitoring system that sticks with the battery in the long haul. Is there such a thing as a separate Li-ion management system that does not compete with a RR Phantom Extended chassis for cost?
Harvard
GordonThree wrote:
The iron phosphate chemistry makes them much safer, at the cost of capacity and performance. The hover board batteries are lithium polymer, very dangerous if abused.
Thanks for that, otherwise I would never be the wiser. ๐Ÿ™‚
3oaks
Facts be known is much better than hysteria of the unknown. ๐Ÿ˜‰
wa8yxm
Xantrex recommends 200+ amp hours per 1,000 watts of Inverter
your Group 31 is 130 amp hours.. you really need 4 of them (though 2 might work).
Recommendation if you can fit 'em is a pair of GC-2.. I know that will work with a 2,000 watt inverter,,though 2 pair is better (recommended).
landyacht318
The two story Lifeline Group 31 is the Lifeline GPL-30HT rated at 150 Amp hours.
When looking at its specs, one might infer the plates are even thicker than the gpl-31XT, and not just taller.
Much more weight for only 25Ah more capacity, and not much more cca either.
I briefly had a GPL-31XT (125AH)in my possession when it was new.
its fully charged resting voltage was 13.16v or higher.
it had absolutely no issues sucking up 100+ amps from a fast spinning capable alternator when depleted to 50%.
Impressive battery.
Not sure if it can handle a residential fridge for long enough for the OP, but if the height is there to fit this tall boy GPL-30HT, then Me thinks it would a very good option, as long as one can be bothered to high amp recharge it at no less than 20% rate, and can regularly achieve a true 100% State of charge
GordonThree
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
BrianinMichigan
2, 6 volt golf cart batteries?
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS,
CAMPING: WHERE YOU SPEND A SMALL FORTUNE TO LIVE LIKE A HOMELESS PERSON.
Bumpyroad
Harvard wrote:
dave17352 wrote:
Well I have been doing a little more reading on these lithium batteries and the look pretty kick a@@! Looks like they do everything better. Now just make them cheaper.
and they do burn good. :B
no danger with that. I mean they have used them in skate boards for years and ........., OH never mind.
bumpy
time2roll
dave17352 wrote:
On these lithium batteries I did not read where you could run them all the way down. I read someplace that you could run them to 80 percent discharge. Do they deliver more power for the surges than a AGM flooded battery?
Yes you may run them all the way down. BMS disconnects above 16v or below 8v. But honestly almost all the energy is between 14.5 and 11.5 so I would stick with that for longest life.
Also no worries about leaving them half charged in storage as this is the preferred storage level.
Cranking amps is misleading as it is just rated 3.5 seconds vs. I believe the CCA definition is for 30 seconds. I would stick with max continuous draw or even 80% as a practical design criteria.
This info is included in the linked documentation.
Huge benefit to solar users is that there is no long slow absorption charge. Lithium pretty much fills to 100% at full speed.
And absolutely no need to provide venting for lithium.
Harvard
dave17352
dave17352
time2roll
GordonThree wrote:
Me too. I'd love to replace my 4x lead G31 with one of the 200 amp 8D batteries, but at 10x the cost, it's not happening. The total cost of over the life of the battery isn't too bad though, you get double the capacity and easily 4x the lifespan... If they can make it into mass production instead of hand-building each one, the price should drop a lot.
I think I will have a couple of the largest in my next RV. Only viable option to run air conditioning from solar. Probably the last battery I buy.
MrWizard
Moderator
Moderator
MEXICOWANDERER wrote:
After purchasing 4 apartment size 120 vac refrigerators for the hotel, I was shocked at how much electricity they porked-out on. The motors ran 24/7 and consumed 90+% of the kWh of a good energy efficient brand of household refrigerator.
Curious
Apt size around 8 CuFt
Our apt size runs less than 50 percent duty cycle
Do you mean Dorm aka Bar fridge
Been stated many times that these tiny Dorm fridges run a lot and use more power then larger ones
I can explain it to you.
1997 F53 Bounder 36s
