path1's avatar
path1
Is this common tire wear?
Michelin ltx or whatever they call their "best" tires. Put on new mid Oct last year (approx. 3,000 miles ago). Mileage is same for every tire on the ground.
I wanted to see if front was wearing even (01 Dodge, not best front end)
Both fronts... wearing flat as could be measured with tire wear gauge, fronts showing 14 mm worth of rubber.
Both rears...are wearing flat but only 8 mm worth of rubber.
Where did 6 mm of rubber go?
Certainly my big mega horse power 5.9 with whopping 235 horse is not peeling the rubber off them?:)
We've had TT hooked up most of those 3,000 miles. Mostly I-5 Seattle to Yuma (via LA area) and a few sight seeing detours. Running 80 psi on rears 70 on fronts. 800 pds tongue weight, maybe 400 in back of pick up bed.
Any comments about where tire wear is going with RV hooked up?
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
