BeachPirate's avatar
BeachPirate
Kitchen Sink Condesation
Never had this issue until this year. This weekend I was defrosting a 10lb bag of Chicken and next thing I know I had water in may cabinets under my kitchen sink. I checked everything and have not leak. When I found the water the sides of the sink basin were wet.
Has anyone else had this issue? Ideas to solve it?
My only thought is the the frozen chicken on the sink basin made it condensate.
Thanks
Bryan
  • I think if you put the chicken in a container of water to that was sitting in the sink you'd avoid the problem with condensation.
  • If you are sure it's not a crack, then it is normal. Happens the same way on your home sink.
  • Sure, if the sink bowl was cold, and humidity high enough, that is quite possible.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
