John_Joey
Apr 16, 2014Explorer
Again I'm not a generator type of guy, other then I dinged on my Kohler 4K. From that experience I can only SWAG at what might be going on with yours.
The Kohler has a computer board in it that senses the voltage and will kill the motor when the voltage gets low enough to damage things. For me it was a bad voltage regulator that was my problem. Kohler's are know for this going bad. Holding down the start button would defeat the board though.
I'm guessing that your voltage regulator is working correctly, but the generator might not be putting out the power that it once did to barely (90 volts according to you) run two AC's. Since you have a Kohler RV generator your rig can not be very new, since they got out of the RV business awhile back. I would think things are starting to get weak with the old gal. If you look in the Kohler manual you'll see you need to do a certain amount of maintenance to keep them running strong other then just oil changes.
I had very good luck with this business when it came to working on my Kohler A.S.A.P. Give them a call they are very helpful and they know what they are doing.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
