DownTheAvenue wrote:
garyemunson wrote:
The A/Cs are much more efficient now. 2 Will run just fine on 30 amps if you switch the fridge and water heater to gas for the hot part of the day and shut one off if you need to run the microwave. Quite doable if you want to stay comfortable. Put #2 on. You won't regret it!
This is vey good and correct information.
Marginal info...when it's really hot is when voltage drops raising the amps. I've seen plenty of burnt up 30amp cords from people trying to max out the 30amps.
If it's cool and voltage is high, it will probably be fine but you likely won't need the 2nd unit.
