CarnationSailor's avatar
Jan 03, 2023
Leaf Spring Failure - Replace the Others?
Last summer I experienced a leaf spring failure on my 2015 Crossroads Rushmore Springfield. The driver's side rear spring snapped in two about 2-inches from where it attached to the frame. After being alerted that the tires on that side were rubbing together, I pulled to the side of the interstate. I had just entered the highway about a mile back, so I was lucky to discover it so soon, and there was no damage to the tires or the trailer. I was very lucky!
AAA got me to a nearby RV repair shop that happened to have a used leaf spring off of a 7000# axle, and it fit my trailer (My axles are 7000# too.) The used spring that was installed appears to be heavier duty than the one that failed. The used one has 7 leafs and each leaf is about 3/8" thick. The one that failed has 6 leafs and each leaf is about 11/32" thick. (1/32" thinner.) Both springs are about the same width.
The tech that installed the used spring recommended that I replace the other 3 leaf springs with heavier duty ones when I got back home. Although the episode could have been a lot worse, I still wouldn't want to go through it again.
Should I replace them, or just consider this event to be an unusual occurence that is not likely to happen again?
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
