psa0298's avatar
psa0298
Leaking toilet blade seal fix
I replaced all the seals in my Thetford toilet about 4 years....it cost about $60...rediculous. Last fall the blade seal started slowly leaking again. I tried cleaning it, scrubbing the groves with a brush, etc without success. I figured they should last a little longer. I decided to order an entirely new mechanism service package(another $60 from amazon).....4-6 weeks delivery time. When I was dewinterizing and cleaning I decided to throw a littlte CLR in the bowl and it has since stopped leaking. There must have been some sort of mineral buildup on the blade that the CLR has removed. I'm not sure if anyone else has tried this but it might be worth a shot before replcing you seals.
Moved to Tech Issues forum from DIY.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
