This is regarding a 2013 Coachman Leprechaun 210QB 23' Class C RV.
My left rear turn signal and left hazard light are not working/flashing. The right rear turn signal and right hazard light ARE working fine.
This happened to me about a month ago. Before I got around to fixing it, it temporarily fixed itself and was once again working.
Today when I went to check on it, I see that it is once again not working.
I wondered if I could get lucky and maybe it is just a fuse. But when I look in my RV's manual I see there is a fuse labeled "Turn signal, Hazard, Stop lamps" which seems to imply that it is controlling BOTH the turn signals, hazard, and stop lamps (brakes?). So since the right side is working fine, I guess it can't be the fuse.
Question: Do this type of rear light setup have individual bulbs, or does it just come as an entire unit? (see photo)
![](https://i.imgur.com/8KME9CXl.jpg)
![](https://i.imgur.com/r01WAgPl.jpg)
Is it a common occurance for these things to go out after ~10years?
-Chris
San Jose, CA
Own two 2015 Thor Majestic 28a Class C RVs
