Leveling blocks on dual rear wheels
standup
Looks like I have to level the old way this summer. Big Foot system is on the sick list.
Using drive-over blocks, is it necessary to support both rear wheels on a side? Is running up on only one tire of a pair an issue?
2014 Class C.
12 REPLIES 12
valhalla360
Nomad III
Nomad III
If you are setting up for regular use, get blocks that accommodate both but...
As long as the tire you block is fully supported, it's not going to cause a tire failure.
What many of those posting don't understand is the difference between static and dynamic loading.
- If I gently set a 50lb bag of sand in your arms, you can probably hold it.
- If I drop that same 50b bag from 10ft up, I'm betting you can't hold it.
That's basically what happens when you compare slowly pulling up onto a block vs hitting a pothole at 70mph. The forces on the tires hitting that pothole are several times what they will see slowly riding up onto a block.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
4x4van
Duplicate post; mod please delete
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
4x4van
My owner's manual says to always block both dual tires.
BruceMc
I cut a number of 10x18" (approx) pieces of old scrap 3/4" plywood for this purpose. I found using 2x boards would split over time, and with a nominal dimension of 1 1/2 inches, I wasn't getting the granularity needed for the desired leveling. The 3/4" plywood has proven to be way more durable than the 2x boards.
This size works for both front and back tires; I stack what I feel will work, but stagger the pieces so it forms a ramp.
I store these in a rubbermaid box (no rubber in those plastic boxes!) in a storage hold, and learned never to put a lid on the box. I stored several once after departing from a site where we got a lot of rain overnight, and the next time I got into the box, they were moldy. The lid got moved under the box and has been there since then. I've never had moldy block since that event.
This has worked for better than a decade of class C ownership, and while the idea of leveling jacks has appeal, I don't care to spend that much (and add additional weight) when the plywood works well for me.
2016 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
Bobbo
If one of the duallies is not on a block, it is not supporting its fair share of weight. If it is not supporting its fair share of weight, the other tire is supporting twice its fair share of weight. It is well known that overloading a tire shortens its lifespan. You don't want to be rolling down the interstate at speed when that tire blows because you shortened its lifespan and it finally failed, leaving you to wonder just WHY that tire blew.
Bobbo and Lin
LouLawrence
^^^^^^^^^^^^This^^^^^^^^^^^^^
IAMICHABOD
I like to go with the recommendations of the tire MFG
such as my Michelin Tires
I prefer and try to block both
I dont believe I'm damaging tires.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
BFL13
I use Rhino ramps. They come in various weight capacities.
IMO one for each wheel of a dually pair, but just maybe not required when parked as there is no tire heat from driving. I use two anyway.
When the back or front is the low end and not level side to side, you place the higher side ramp(s) a bit out from the tire(s) that side so the whole end goes up but not as far up the one side's ramp(s) as the other's.
I have a level on the dash for side to side and on the driver's door inside so I can see when it is right. Shut down and stomp on the parking brake. ( Check on the way up that you don't drive up and off!
The ridge at the end of the ramp only helps a little. BTDT)
They do take up space and get dirty and wet but there is room in our C in outside compartments. Usually carry four but it could take six. Mostly find only need two
https://www.princessauto.com/en/16000-lb-rhino-vehicle-ramps/product/PA0008607582
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Lwiddis
Iโ€™d be safe and level with blocks under both wheels.
way2roll
Navigator II
Navigator II
On a previous MH without jacks we used blocks and put one of the rear wheels on. I tried to make sure it was the inside wheel. This was a pretty light entry level MH. Never had an issue.
corvettekent
That would depend on the weight. You might crush the plastic blocks. Wood blocks would hold up under one tire.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Grit_dog
Navigator
Navigator
Only an issue if it's too bouncy. Your tires see much more dynamic load than static load. It'll sit on one tire just fine.
