jaycocreek
Apr 19, 2021Explorer II
I don't pretend to understand a lot of this but reading this explains the 12.8 nominal voltage...
Lithium batteries are an assembly composed of many cells, like lead-acid batteries and many other battery types. Lead-acid batteries have a nominal voltage of 2V/cell, whereas lithium battery cells have a nominal voltage of 3.2V. Therefore, to achieve a 12V battery you’ll typically have four cells connected in a series. This will make the nominal voltage of a LiFePO4 12.8V
Then there's the 14.6 vs 14.4 and resting voltage seems to be 13.6ish...Very confusing sometimes...
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
