- down_homeExplorer IIA lot of Lithium Ion batteries going nuclear and just catching fire.
Bought a 40 volt chain saw for light work.
Charging the battery it smelled like it was ready to catch fire. The case surrounding the actual batter is generous so it only got warm.
I'm going to charge it outside the garage on an external outlet from now on. - MEXICOWANDERERExplorerYotta take a look at the sheet metal top of my kitchen hobby table.
Wodda idiot I am. Connected the wrong voltage regulator to a salvaged NOOK Li-ion battery.
I'm almost deaf but I did not miss the "KA-POW!" in the bedroom. Rushed out to FOUL smelling smoke and glowing embers strewn across the concrete floor. That'll learn me to not connect 24% over-voltage to a lithium rechargeable battery. - mena661Explorer
Canadian Rainbirds wrote:
Depends on how long each event happens as to the results in my research. There can be fires in each case but, again, depends on how long the batteries remain in those conditions. Yes, the batteries could hold up for HOURS or even DAYS under those conditions. LI batteries typically used for RV duty are a different, less volatile chemistry than those used in EV's. Much safer.
Cool! And interesting, thanks. However it doesn't show what happens under overcharging or catastrophic short circuit. - Canadian_RainbiExplorerCool! And interesting, thanks. However it doesn't show what happens under overcharging or catastrophic short circuit.
From you topic title I thought for a minute that you had (inadvertently) done a test to destruction trial!
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 20, 2026
