time2roll
Mar 06, 2018Nomad
Consider a lithium battery replacement to eliminate the need for top charge. 90% charged is actually preferred and is very easy as absorption time is fast. This also makes solar more efficient. A bit more money up front however a good value if full time off-grid. Smaller capacity is fine as you can freely use 80% of the capacity instead of 50% for lead-acid.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
