LittleBill
Jul 24, 2019Explorer
Itinerant1 wrote:
I believe he means balancing.
do you have to reach a certain voltage for balancing to occur? i though the balancers worked continuously? not sure how the bms in them work
according to the battleborn faq need to be over 14v
"A passive balancing process is activated by the BMS at the top of each charge cycle, when the battery voltage exceeds around 14V. This ensures that all the cells remain at the same state of charge, which helps for pack longevity and performance"
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
