โOct-30-2018 10:49 PM
โNov-04-2018 09:56 AM
โNov-04-2018 09:29 AM
โNov-04-2018 08:58 AM
โNov-04-2018 08:09 AM
โNov-04-2018 07:34 AM
โNov-04-2018 07:17 AM
โNov-04-2018 06:45 AM
Itinerant1 wrote:BFL13 wrote:Itinerant1 wrote:BFL13 wrote:
"...there won't be any charging from solar a 1 or 2 hours hold over charge from the eu2000i will give a 100-200ah back in the..."
How can you put that many AH back in with a 2000w gen that can run say a 70amp charger at the most? Two hours x 70 amps is 140AH.(and take off some of that for heat)
I do not question your Li battery bank performance etc as reported. Just fussy about battery charging math.
MSH3012M will charge at 125 amps using 18 amp max from the generator. So in my case I set the incoming load to 15a as not to overload the generator and charging at about 100+/- amps.
18 amps max / 15 amps which it's set for = 83%
.83 X 125 amps dc = 104 amps
LFP will just gobble that charge with no heat showing in cells. ๐
I just don't understand how the 13.3 amp Honda 2000w gen can do that. I do know the charger is PF corrected in this case.
Eu2000i AC Output:120V 2000W max.(16.7A),1600W rated (13.3A). Using the load support on the Inverter/ charger it can be set 1-50a. If I were to set it at 17a you can hear the generator working at full bore as you lower the amp setting by 1a you can hear the generator slightly slowing down or not running full bore. 14-15a set on the Magnum seems to be the sweet spot and charging is 100ah +/-.
If you would like to see recorded readings in an Excel sheet from the system, there are 2 displays, 1 is for the LFP batteries and the 2nd for the Magnum inverter/ charger & pt controller. The top line should basically explain what is being recorded from what display.
Charging readings are highlighted in orange 9/23/17, 5/12/18, 9/19/18, 9/23/18
Other than that all I can say it works.
โNov-04-2018 06:32 AM
โNov-03-2018 11:24 PM
โNov-03-2018 08:15 PM
โNov-03-2018 08:10 PM
โNov-03-2018 07:33 PM
pnichols wrote:
"Powerwall" sounds like a Tesla buzz-word marketing term to me.
What are the details on it's components and how they play together - really?
i.e. Just a generous capacity lithium battery - flat configuration for wall mounting - an inverter somewhere - what goes outside the home verus inside the home - etc?
You gotta love those tech sounding fuzzy product names and descriptions nowadays.
โNov-03-2018 06:57 PM
โNov-03-2018 06:23 PM
โNov-03-2018 06:14 PM
