Cydog15's avatar
Cydog15
LifePO4 batteries
Figured I'd repost this, start over and maybe the same 4 or so guys that hijacked it would be tired out and let others that ARE using LiFePO4 get a word in and discuss it.
I see a lot of folks are transitioning to Lithium and it reminds me of Solar when it first became popular. It was all about cost per watt. Well there are several companies selling lithium at about the $10 per amp range. BB seams to be the cheapest but their BMS is internal.
Found the Expion 360 line that Airstream is selling and it's 120 Amps in a group 24 box/case whatever you call it. Also has an external BMS that is user serviceable should it ever fail. That got me interested. Anybody using them and what are your thoughts? It does weigh a couple more pounds presumably because there are a few extra cells to get 120 amps in that smaller 24 group box. They also have a monitor that does all of the same things as the Victron and everything is visible on the screen so it's not like the old Xantrex where you have to toggle through the pages. Thoughts?
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
