I think my 2 100AH LiFePo4 batteries are ok. I have not used them yet other than on 2 day trips due to my health. My alternator has a max capacity of 117 amps. It connects via #8 wire through 2 40 amp mini breakers to a battery isolator and then to the house batteries. I am attaching the specs for those batteries including the BMS protection, not sure if it will come. I hope you guys can confirm I am OK.
I do not know how to change this pdf file to a jpg I can attach. I could scan it into my pc then attach.
file:///C:/Users/Steve/Downloads/12V100Ah%20with%20BMS%20specs.pdf
It says max continuous charge current is 50 amps, and the max charge current is 60 amps or less.
