mchero's avatar
mchero
Locating a neutral buss bar
Assisting an RV'er in an older gasser that had a neutral buss bar meltdown. Stranded neutral feeding the buss bar connected to the lowest connection, Heated up, got real hot and discolored above neutral taps and partially melted bus bar into plastic insulator.
Well, above RV'er made a mad dash down to the local RV repair and was told she needed e NEW Xfer switch! Well, in my eyes all she needs is a new neutral bus bar! Looks as though this bus bar is pop riveted in two places to the side of the panel.
Any online sources for such a bus bar? I'd say about 8 to 10 connections, I forgot to get a picture. I'm in Quartzsite so today I'll sniff around town to see if I can locate something.
That time of year people plug in electric heaters and find out the hard way they have a bad connection.
Thoughts ideas?
Thanks all
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
