N-Trouble's avatar
N-Trouble
Logging trailer miles
I'm to lazy to log my miles on every trip with the trailer, but would like to know the mileage for maintenance purposes. Does anyone make a low cost digital unit similar to what you can buy for a bicycle with a magnetic pickup attached to inside of wheel? Program in your tire size and outputs miles.
  • Semi trucks and trailers use a "hub-o-meter", you may be able to get one for your RV trailer.
  • I thought about one for old RV but when looking at its maintenance schedule I changed my mine.
    Unless you tow a lot of miles... what maintenance item(s) "miles" out before it "times" out?
  • AH64ID wrote:
    I reset my 2nd trip meter when the trailer gets hooked up, then write down the mileage when I unhook.
    2X.
  • I reset my 2nd trip meter when the trailer gets hooked up, then write down the mileage when I unhook.
  • I log our trips in a log book I got from my dad that he used. It list place from/to, mileages from/to, where stayed, cost to stay, maint. cost, notes about what we saw, weather, etc. Can review it anytime.
  • My F250 has a "productivity screen" that records the mileage when a trailer is hooked up. Pretty slick setup.
  • valhalla360 wrote:
    Unless you are towing a lot, just plug in your recent trips into Google Earth (or similar mapping program).
    It will spit out the mileage close enough for maintenance tracking purposes (and most other uses)
    I do the same with Streets & Trips.
    Pat
  • Unless you are towing a lot, just plug in your recent trips into Google Earth (or similar mapping program).
  • Couldn't remember the name - finallly did - "hubodometer"
    Dunno about building one but I googled and they are about $30 to over $100 - depends on tire size. Here's one style on Amazon But google "STEMCO Hubodometer" should get you going.
    Good Luck!
  • Community Alumni's avatar
    Community Alumni
    Not applicable
    Here's one designed for RV trailers but it will set you back $100.
    http://www.rvsolutions.us/
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
