Fisherman
Jan 18, 2022Explorer
dougrainer wrote:Ex-Tech wrote:
Cover the burner up and remove the roof vent to access the flue tube and use a wire brush with a long wire handle. (These are available at HVAC supply houses).
Push and pull the brush up and down a few hundred times to remove the rust. ;)
What do you do about the spiral baffle??????????????? Doug
Once the roof vent is off, lift up the spiral baffle and clean it off.
